06-07-2010 11:20 AM - edited 07-03-2021 06:51 PM
I am working at a client site whom is running a fairly recent version of ACS. They have some old group names under Network that they want to change to make their descriptions more valid. Is it possible to change Network Device Group Names in ACS? How about changing just "Group Names".
Kevin
Solved! Go to Solution.
06-07-2010 06:17 PM
Hi Kevin,
It seems you are asking about ACS 4.x. IF that is the case then yes, we can change NDG name.
Editing a Network Device Group
To edit an NDG, you must first access the NDG. To do so, click the name of the NDG in the Network Device Groups table. Click Edit Properties at the bottom of the page.
For changing individual aaa-client we need to delete and readd it.
~JG
DO rate helpful posts
06-07-2010 06:17 PM
Hi Kevin,
~JG
