QoS Question / match protocol citrix
Answered Question
Jun 7th, 2010
What port(s) does / do the keyword "citrix" match?  Where is this defined?  Is it editable?
Thanks, Mike.
12.4 series code on 28xx routers
Correct Answer by gatlin007 about 6 years 4 months ago
'show ip nbar port-map' should reveal the ports each protcol is using to classify traffic.
In global config mode 'ip nbar port-map' may be used to modify the ports being used.
The 'ip nbar custom' command can also be handy.
Christopher Gatlin
Overall Rating: 5 (1 ratings)
David Hailey Mon, 06/07/2010 - 11:46
Take a look here.  It's a pretty good resource: support.citrix.com/servlet/...102.../Cisco_Networking_Integratio.pdf (Also attached).
With match protocol citrix, you can optionally specify individual applications.  If you leave it as-is, then it establishes all Citrix traffic as successful match  criteria.  The various apps and ports are outlined in the attached PDF.
Please rate helpful posts!
mlpalmer Mon, 06/07/2010 - 11:51
That doesn't sound right.  80 and 443 are in the port table of the pdf.
mlpalmer Mon, 06/07/2010 - 12:44
Host#sh ip nbar port-map
port-map citrix                   udp 1604
port-map citrix                   tcp 1494
Thanks, answered my question.
