stable IOS for ASA 5510?
Panos Kampanakis Mon, 06/07/2010 - 17:48
  • Cisco Employee,
8.2.2 and 8.3.1 have most of VPN issues fixed and they are definitely better than 7.0 that is no longer been developed.
You need to be more specific on that the issue is.
Do VPN tunnels go down?
What do you logs say as a reason?
What issues are you facing exactly.
If this is VPN related iI would also suggest the VPN section of the Security forums.
PK
