Ip Phone 7925 & CME Version 4.1(0)
sreed
Configuring a new 2801 ISR running Version 12.4(15)T10 IOS & Version 4.1(0) CME.
I'm trying to add a 7925 Wireless IP Phone. I downloaded the CP7925G-1.3.4SR1.tar which is supposed to be the latest 'Skinny Client Control Protocol (SCCP) Software' and according to the " ... Release Notes with the Cisco Unified Wireless IP Phone running with Cisco Unified Communications Manager 6.0 and later, and Cisco Unified CallManager 5.1, 4.3, 4.2, and 4.1. "
When I import the files using 'archive tar /xtract tftp://172.16.1.11/CP7925G-1.3.4SR1.tar flash:' The files import to a folder flash:/P7925G-1.3.4SR1. but I can't get the system to recognize them.
I deleted them and repeated the import using CCP 2.2. Again the files imported to the folder but still they are not recognized.
Help!
William Bell
It does not appear that the 7925 is compatible with CME 4.1.  First compatibility matrix that shows the 7925 is for CME 4.3:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme43spc.htm
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Will,
You are completely rigth, he needs al least CME 4.3 to use the 7925 wireless IP phone.
Please rate this post if was helpful
Walter Solano
Cisco UCCX Specialist
Bill is right on the spot, read the doc:
Cisco Unified Wireless IP Phone 7925G
Protocol  support
• Skinny Client Control Protocol (SCCP)
• Cisco Unified Communications Manager Versions  4.1, 4.2, 4.3, 5.1, 6.0, 6.1, 7.0 and later
• Cisco Unified Communications Manager Express  Version 4.3 and later
• Cisco Unified Survivable Remote Site Telephony  (SRST) Version 4.3 and later
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps379/ps9900/data_sheet_c78-504890.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
