Hunt Groups and call pickup
Jun 7th, 2010
There are five extensions within a Hunt Group. One of the users wants to pickup the call before it cycles around to the hunt group to her extension number. Is she able to use call pickup to do this?
William Bell Mon, 06/07/2010 - 20:06
  • Purple, 4500 points or more
Jenny,
There is a defect that may be of interest.  I have seen this floating around the netpro forum from time to time.
See this kb:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11612191
The idea is you modify the Enterprise Parameter Cisco Support Use 1 and add the value CSCsb42763.
While the KB is focused on 4x, this fix has been viable for 5x/6x/7x.  My understanding is that this feature existed at one time and then was removed from the code.  Customers complained, and a workaround was created.  Sort of an easter egg?  There is a good thread and discussion from Rob Huffman on this here:
https://supportforums.cisco.com/message/1326939#1326939
Anyway, you may want to test this out to see if it fits the need.  I myself have not tested this on a 7x version.
HTH.
Bill
Please remember to rate helpful posts.
Tracy Larson Mon, 06/07/2010 - 20:14
  • Silver, 250 points or more
Bill is correct that is the code you put in the service parameter field. I opened a TAC case on this a while ago and it matches with what I have. It does work with 7.x as I am on 7.1.3. The nice thing is, after you put that in there another input box shows up in case you ever need to add another one in the future. When I was on version 4 that was not the case.
