Voicemail Issue (message are not being saved in the mailbox)
Jun 7th, 2010
cuecliad.fmb /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
I am having problems with voicemail in a new UC520.
Phones connected to the UC520 are able to call to PSTN and Local extensions but they are not able to leave a voice mail.
Let me clarify this:
When Phone A calls Phone B and Phone B does not answer. The call is forward to voice mail (888). User using the phone A will get a message saying “extension B is not available please leave the message after the tone” . User A left the message but it does not appear in User B Mailbox.
show voicemail detail mailbox userA     does not show message at all
Below is my configuration related with Voice mail
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
dial-peer voice 2015 voip
  description ** cue voicemail pilot number **
destination-pattern 888
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
telephony-service
voicemail 888
ephone-dn  11  dual-line
number 302 no-reg both
pickup-group 111
label 302
name UserA
call-forward busy 888
call-forward noan 888 timeout 10
ephone-dn  13  dual-line
number 304 no-reg primary
label 304
name UserB
ephone-dn  55
number A801... no-reg primary
mwi off
ephone-dn  56
number A800... no-reg primary
mwi on
CUE
username UserA create
username UserB create
username UserA phonenumber "302"
username UserB phonenumber "304"
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 6
script "voicebrowser.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn subsystem sip
gateway address "10.1.10.2"
end subsystem
ccn trigger sip phonenumber 888
application "voicemail"
enabled
maxsessions 6
end trigger
voicemail callerid
voicemail default mailboxsize 1200
voicemail broadcast recording time 300
voicemail default messagesize 180
voicemail mailbox owner "UserA" size 1200
end mailbox
voicemail mailbox owner "UserB" size 1200
end mailbox
Any idea ?
David Trad Mon, 06/07/2010 - 22:55
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi There,
I would like to clarify a few things with you if that is ok:
  • Is this a new install? if so,
  • Was CCA used to configure the system? If not,
  • Did you initialise the CUE? Either by Command line or the Web GUI?
  • What happens when you click the envelope button on the phones, or if you dial 888?
  • Do you receive the introductory announcement from the CUE attendant? (First run until the phone has created a mailbox will be "Welcome to Cisco Unity Express, Please take a moment.......")
  • What version of CUE are you using?
  • What version of CME are you using?
What ever you can answer in the most detailed way will go along way to assist you and resolving the issue.
I look forward to your next post.
Cheers,
David.
juliocv99 Tue, 06/08/2010 - 07:03
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
No, this is router was in use before, but now I am reconfiguring it
I am using the CLI.
Yes I did by CLI
     When I call 888 at the first time I got welcome message from Cisco Unity Express
Software Version: 3.0.3
Voice Mail (2.3.1.0)
Auto Attendant (3.0.0.12)
Installed Plug-ins:
CUE Voicemail Language Support (3.0.0.0)
CUE Voicemail US English (3.0.0.0)
uc500-advipservicesk9-mz.124-11.XW7
Probably I should update the CUE version
Could you tell me which version I should put?
I want to do this using CLI; can you provide me documentation for this?
Thanks in advance
David Trad Tue, 06/08/2010 - 22:16
    2013 Small Business
Hi There,
Sorry for the late reply
I am a strong advocate for always upgrading to the latest or closest to the latest, it might not always be the smartest decision but I still consider it a good decision.
Anything in the 7.X.X series, the later you go the better they are, but you also need to make sure you have the right GUI files located on the flash card as well, make sure you download the right GUI files for that particular CUE and replace/delete the old ones with the new ones.
this?
I don't have a document for this, but I have written it on these forums so many times I have lost count, and I still can not work out why I have not written up instructions on how to do this yet, I should one day.
This is a very quick and shroud guide, if you need more information I just might have a document done up by then.
Download the following software:
  • http://support.3com.com/software/3cdv2r10.zip
  • Either the latest UC-5XX software pack or the latest CUE you want to use (Take note CUE 7.1 May require you to download a new license, if you do not want to go through all those troubles then stick with the 7.0.X series)
  • A good ZIP utility, if you are like me and like small, low resources application, then 7zip is a good application
  • Putty which I am guessing you already have
NOTE: Given the age of your CUE you will need to do a two stage upgrade, first one will need to go to 3.2 and then you can upgrade to the 7.X.X branch, do not attempt to upgrade to the latest or it will fail and you will yell, scream and curse everyone (Speaking from first hand here ).
What you will need:
  • Time and a bit of it (Around the 1 to maybe 2 hours, more if you are running into small problems
  • Coffee or your favorite beverage
  • A Cool head, because if you are doing it via CLI then you are taking a huge risk
  • Above all patience (I remember Dave Harper telling me this, I couldn't stop asking if it was finished already )
What you need to do next:
  • Install all applications required
  • Create a "TFTP" Directory on your hard drive, I REALLY recommend creating this on the root of your drive i.e C:/TFTP/ or D:/TFTP/ this makes life so much easier and less troublesome.
  • Create a "FTP" Directory exactly the same as above
  • Configure 3Cdamon to point to those folders respectively i.e TFTP to point to TFTP folder... and so on
  • Where you are asked to create a password and username, keep it simple, something like cisco and cisco123 is what i recommend
Before we proceed: I would prefer you reconsider doing this via CLI and honestly look at using CCA 2.2.4, it is an automated process and ontop of that it creates a backup and a restore of the CUE, when doing it manually the restores can fail, and in your case you may get a partial fail because you are upgrading to a really high version from and old one, even if it is a two stage process.
Final Checks and backups:
  • Are you sure you want to do this manually? Ok..Ok if you insist
  • Log onto the Web GUI of your current CUE, click on Systems and set your FTP server details up (Remember the ones you configured in 3Cdamon?) make sure you get this right otherwise it wont work
  • Proceed to the Administration section and create a backup (If sucessfull it will put your CUE in offline mode and copy it to the FTP folder)
  • Once completed navigate to the FTP directory and right click on the folder and check its size, if is is like a few megabytes in size then something is wrong, unless on that version not much is saved when you do a backup.
  • If you want another language other then U.S.A then this is the time to download it and put it in your CUE folder that you just recently downloaded
Now the part that can make or break your system:
  • Session into your CUE module
  • Type the following: software install clean ftp:///FTP/ username cisco password cisco123
  • If that was successfull then it will verify the file you have pointed it too, and again if you chose the right file it will proceed with the upgrade
  • You will see a bit of chatter on the screen, and at some stage you will get a prompt asking you what language you want to install (You can only choose one), pick the number that corresponds to the language you want (This is the audio files) and then press "x" to exit out of that.
  • The CUE will begin its upgrade process
  • DO NOT TURN OF THE POWER
  • DO NOT INTERRUPT THE UPGRADE PROCESS
I recommend walking away and making a coffee or tea right now, this process will take a while (Up too 40 minutes or even more).
NOTE: You will see a lot of "#" Symbols at one stage and the system counting upwards, this is the load process and can take quite some time to do
Final stage:
  • One the upgrade is finished you will see the command line come back up and it may even ask you to initialize the system
  • Exit out and do not initialise it on the command line
  • Now make sure the new GUI files are on the card and the CME is pointing to the /gui directory
  • Browse to the new CUE GUI and log onto the system (At this stage it may be cico/cisco)
  • Initialize the system by following the onscreen instructions
  • Synchronize the CME to the CUE (In some cases your previous CUE system might be auto restored after the upgrade, in this instance the Synchronization will error out if it finds double ups)
  • After you have finished the Initialization and the Synchronization you can proceed to restore your backup
  • Go to System and check the FTP setting, input the same ones as you use last time
  • Go to Administration and point to Restore
If all goes well you should be back to normal within a couple of hours.
Hmmmm I think I just wrote up the whole process without realizing I hope I didn't miss any steps.
Good luck with it and I hope you succeed.
Cheers,
David
