HP Port teamin and cisco switch
Answered Question
Jun 7th, 2010
I am planning to start using port teaming on a HP DL360 G6 server that is connected to a Cisco Catalyst model  2960. Are there any special configuration that I need to make on the Cisco Catalyst in order for the port teaming on the HP server to work?
Regads,
Correct Answer by Hitesh Vinzoda about 6 years 7 months ago
That depends upon what kind of teaming you gonna use..
1. Fault tolerance >> No configuration required on switch side, use the same port type access/trunk
2. Transmit Load Balance with FT >> no configuration required on switch side, use the same port type access/trunk
3. Switch assisted FT >> Etherchannel using LACP for bundled ports on switch.
For further reading please go through below link for teaming
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01415139/c01415139.pdf
Hope this helps
Hitesh Vinzoda
Pls rate useful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Hitesh Vinzoda Mon, 06/07/2010 - 22:39
Hope this helps
Hitesh Vinzoda
