cisco 3550 Qos DSCP marking
Jun 8th, 2010
I have the following setup :
device marking dscp  >------>trunk port [3550 switch] ----- access port---------> management computer
The device is marking with dscp 6 in upstream. I need to be able to recognise the dscp 6 marking on the switch and also performing the dscp marking 6 on downstream on the switch for allowing traffic to pass.
Also, I need the management computer to be able to access the device marking dscp, meaning that I need to replace the dscp marking with no marking.
I have the following config :
interface FastEthernet0/1
description TRUNK_4MOTION_ODU
switchport mode dynamic desirable
service-policy input ACS
mls qos trust dscp
interface FastEthernet0/5
description MANAGEMENT_CPE
switchport access vlan 1101
switchport mode access
spanning-tree portfast
access-list 120 permit ip 10.101.0.0 0.0.0.255 any dscp 6
ip dhcp pool MANAGEMENT_CPE
   network 10.101.0.0 255.255.255.0
   domain-name test.com
   default-router 10.101.0.254
   option 60 ascii "dslforum.org"
   option 43 ascii "InternetGatewayDevice.ManagementServer.URL=http://10.101.0.252:8080/dps/TR069"
   lease 0 0 5
class-map match-all ACS
  match access-group 120
policy-map ACS
  class ACS
   set dscp 6
For some reasons I cannot pass any traffic between the device marking with dscp 6 and my switch.
What am i missing ?
Liviu,
Fa0/1 is a trunk
Fa0/5 is a switchport in vlan 1101
By default all packets recevied on the trunk ports WITHOUT a dot1q marking in the layer 2 header will be assumed to be on VLAN 1.  Since the trunkport is in VLAN 1 and your management station is in VLAN 1101 - you need inter VLAN routing.
HTH>
liviu.sisu Tue, 06/08/2010 - 04:37
Hi Andrew,
Thanks for your prompt response.
I think I already "instruct" the trunk port to accept qos-marked packets.
I am not quite sure if I got your point. Inter-vlan routing is being done at the moment on the 3550 switch.
My concern is not on that side, but I assume i am doing something wrong on the policer side.
Liviu
liviu.sisu Tue, 06/08/2010 - 05:04
The device marking the traffic should get an IP from this pool :
   lease 0 0 5
And it gets it.
The management computer's IP address is on 10.101.0.252 and it is on VLAN 1101.
Behind the CPE I am using multiple VLANs, that's why I am using trunking.
On the switch side, I want to be able to recognise dscp 6 marked on the CPE, assign an IP from DHCP pool residing on VLAN 1101 and be able to pass traffic.
At the moment I cannot ping the device performing marking.
