automatically changing the trunk
Jun 8th, 2010
hi friends,
i am having 2851 ccme and i am having 7 analog lines and one 30 channel PRI line
what i need is once the analog lines are used (full ) then automatically system has to select pri line to call outside
and i am using 9 to dial out.
i attaching my config in this
in my config there is two access one is 9(for analog line ) and 0 (for pri line)  and some direct numbers are there in PRI line.
thanks
cyril
zeuscyril Tue, 06/08/2010 - 23:00
hi jonathan,
can you explain me with my config it is very helpful to me becuse i tried it , but i am getting confused.
thanks
cyril
