Compatibility between Cisco AP & products
Jun 8th, 2010
Hello all,
I would like to check if Cisco AP is compatible with /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} Motorola WT4000 Series and Zebra QL Plus Series Printers.
Cheers
Elliott Shawd Fri, 06/18/2010 - 17:58
Yes. I didn't look too closely at each model of these devices, but make sure "WiFi" is included in the specs. It seemed all of the Symbol PDA devices were WiFi compatible, but I'm not sure about the printers. It seemed the 420 Plus printer included wifi.
