[Resolved]dcrcli using DCRCLIFILE LMS 3.2
Jun 7th, 2010
I'm using the LMS 3.2 on a Windows Server 2008.
I've got an issue in using dcrcli with DCRCLIFILE.
I correctly wrote the DCRCLIFILE.
dcrclifile.txt
admin network
and I added the enviroment variable with the right value.
DCRCLIFILE=c:\Program Files (x86)\CSCOpx\conf\dcrclifile.txt
When I ran this following command, I've got this result.
C:\Users\wdeloraine>dcrcli -u admin
<dcrcli> * Password file found using DCRCLIFILE environment variable.
Exception in thread "main" java.lang.NoClassDefFoundError: Files
I searched JAVA error but it is too general.
Could you help me on this subject?
Thanks, Best regards.
william.deloraine Tue, 06/08/2010 - 02:09
I changed the path of the DCRCLIFLE.
The path doesn't contain any space "DCRCLIFILE=c:\Program  Files (x86)\CSCOpx\conf\dcrclifile.txt".
The path is now c:\temp\dcrclifile.txt.
The problem has been fixed.
