ccx outbound campaign not starting
Dears,
I have UCCX 7.0 and I am facing the following problem:
I configured an outbound campaign and the agents which are in ready state are not prompted to accpet any call. The % of  logged agents is 100%. Direct Preview is enabled in CDA.
I also tried a few days ago to configure another campaign and it worked fine. What could be the problem?
Your help is really appreciated
Hi Moustapha
If it was working a few days ago, then what you can try doing is disable the campaign.
Load up the dialing list and then renable it again.
Give it a few min and see if its dialing, also check via the RTMT tool of the outbound service is also running.
