06-08-2010 04:41 AM - edited 03-19-2019 01:02 AM
In Device Profile configuration I want to know what is the use of "Log out (default profile) information):Login User ID [where we can select users].which will be available in the bottom of the page.
How it will be used when we are using Extension Mobility.
Hari
06-08-2010 04:59 AM
Hari,
This is an optional parameter. The scenario it applies to is if you set up your Extension Mobility phones to have a logout profile. To illustrate:
Suppose you have:
1. Device Profile: Hari_Profile
2. Device Profile: Logout_Profile
3. Device: SEPAAABBBCCCDDD
Assume that SEPAAABBBCCCDDD is enabled for extension mobility. When you enable the phone for extension mobility you have to tell the phone how you want it to behave when a user logs out of the phone. You can tell the phone to use the configurations assigned to the phone itself or, it can take on the identify of another device profile.
If you select to have the phone use its local config on logout:
1. Hari logs on to device with Hari_Profile
2. The SEPAAABBBCCCDDD configs are replaced with Hari_Profile configs
3. Hari uses the phone and after some time logs out
4. Hari_Profile is replaced with SEPAAABBBCCCDDD config
If you select to have the phone use a logout profile:
1. Hari logs on to device Hari_Profile
2. Hari_Profile configs are applied to the phone
3. Hari uses the phoen and after some time logs out
4. Hari_Profile is replaced with Logout_Profile config
This Logout_Profile needs a user ID assigned, so the system can associated the logon event with a user. Which brings us back to your original question.
HTH.
Bill
Please remember to rate helpful posts.
06-08-2010 06:10 AM
Hi Bell,
Thanks for your Detailed answer,
But my doubts are
Already we will have a default device profile configuration(ADP) over phone so what way it will benefit.Could you please give me a real-time example ?
ALso after logged-in user logged out from phone then the specified log-out profile has to be loaded at that time whether it will ask for PIN (Since we specified user id in Logout Profile) ?
Hari
