06-08-2010 05:53 AM - edited 03-11-2019 10:56 AM
Attempting to set up the FWSM in transparent mode (single context). Here is my scenario: I have a 6509 with 3 VLANs…40 (DMZ), 41 (Staff), and 42 (Inside). I would like to use the FWSM to control access transparently between the 3 VLANs.
Here is what I have set up:
6509
firewall multiple-vlan-interfaces
firewall module 7 vlan-group 40
firewall vlan-group 40 40-42
interface Vlan40
ip address 10.40.0.1 255.255.255.0
interface Vlan41
ip address 10.41.0.1 255.255.255.0
interface Vlan42
ip address 10.42.0.1 255.255.255.0
FWSM
FWSM Version 3.1(10)
firewall transparent
interface Vlan40
nameif DMZ
bridge-group 1
security-level 0
interface Vlan41
nameif Staff
bridge-group 2
security-level 50
interface Vlan42
nameif Inside
bridge-group 3
security-level 100
access-list DENY-ALL extended deny ip any any log
access-list DENY-ALL extended deny icmp any any log
access-group DENY-ALL in interface DMZ
I understood that without any ACLs, the default action would be deny, however I was able to communicate freely between all the VLANs. I added the ACL to explicitly deny anything from the DMZ, but still able to communicate.
Would appreciate any assistance in how I can get the FWSM in transparent mode to control traffic between 3 VLANs.
Solved! Go to Solution.
06-10-2010 11:20 AM
Vlan 40 and 41 should be in the same subnet.
But hosts on switchports vlan access 40 and 41 will go through the FWSM that will be bridging these vlans.
So make sure you have 2 ports with hosts in each vlan and that their ip addresses are in the same subnet.
try pinging between them and then the FWSM should be bridging and you will see traffic through it.
I hope it helps.
PK
06-08-2010 07:12 AM
Pls. follow the sample here: http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/exampl_f.html#wp1029042
You need two vlans in a bridge group.
Transparent firewall overview: http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/fwmode_f.html#wp1220104
-KS
06-10-2010 07:16 AM
I "think" I followed the instructions ... placing two VLANs in a single bridge_group (although that goes against everything I believe about routing!) ... but still can not seem to control access between VLAN 40 & 41. I still have full access between devices on both subnets.
interface Vlan40
nameif DMZ
bridge-group 1
security-level 0
interface Vlan41
nameif Schools
bridge-group 1
security-level 50
Appriciate any advice.
06-10-2010 11:20 AM
I hope it helps.
PK
06-10-2010 11:36 AM
Thank you...that was my misunderstanding. Both VLANs are using the same subnet linked back together by the bridge-group --- the pieces all fit now!
06-10-2010 11:45 AM
Yup, glad it helped.
PK
