MSFC placement in FWSM Deployment
Answered Question
Jun 8th, 2010
Hello everybody,
I was going through the FWSM configuration guide and came around a concept of placing the MSFC in front or back of the FWSM. What i have understood is if you create a VLAN10 and assign this VLAN10 to the FWSM and then create the SVI for this VLAN10 on the MSFC then you have placed the MSFC behind the Firewall module and if you have create the SVI for this VLAN10 on the FWSM instead of the MSFC then you have placed the MSFC in front of the Firewall module. I wanted to know if this understanding is correct If not can you give me the right concept.
Thanks in advance for you answers
Correct Answer by Kureli Sankar about 7 years 2 weeks ago
Sheikh,
I believe you understood this perfectly.
What the doc. says is correct.
[ In the left-hand example, the MSFC routes between VLANs 201, 301, 302, and 303, and no inside traffic goes through the FWSM unless it is destined for the Internet. In the right-hand example, the FWSM processes and protects all traffic between the inside VLANs 201, 202, and 203.
This would only be possible if the SVIs for these vlans is on the MSFC, if the SVIs for these vlans would have been on the Firewall then traffic will ahve to go through the FWSM.]
[KS] When the MSFC (with layer 3 interfaces on all these vlans) is on the inside then all these vlans 201,301,302 and 303 are considered inside vlans.  Traffic between them will not even go to the firewall.  Again, like you said you can create interfaces on the firewall but, still the MSFC will not send the traffic to the FWSM if it knows (directly connected SVI for all the vlans) unless it is specifically told to do so via route map and set-ing the next hop to the FWSM interface address for traffic between vlans.
If you want to firewall traffic between vlans 201, 301, 302 and 303 would have to follow the rigth side picture. Think of this as a PIX/ASA with many DMZs configured and the MSFC on the outside, just like any other layer 3 routers connected to the ISP and out to the internet.
Is this clear? If not pls. post your question.
-KS
Overall Rating: 5 (1 ratings)
Kureli Sankar Tue, 06/08/2010 - 06:46
  • Cisco Employee,
Sheikh,
Not really. It depends on the nameif for vlan10
msfc---vlan10--(inside)FWSM(outside)-vlan20--another_layer3_device---internet  -----> in this case MSFC has int vlan 10 created (SVI)
In this case vlan10 is your inside interface for the FWSM and so the MSFC is behind the FWSM.
If you have
inside hosts----Vlan10----(inside)FWSM-(outside)vlan20---MSFC---internet  ----> in this case the switch has int vlan 20 created (SVI)
Now, the MSFC is on the outside.
-KS
sheikh ahmed zubedi Tue, 06/08/2010 - 07:48
hi kusankar,
Thanks for you reply. i have one doubt as i was reading chapter one of Cisco's FWSM configuration guide under using the MSFC section
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/intro_f.html
it shows that vlan 201 is considered inside when it is between the FWSM and the MSFC but on the right side of the diagram it shows now that vlan 201 is behind the firewall and it says
The document says For multiple context mode, if you place the MSFC behind the FWSM, you should only connect it to a single context. If you connect the MSFC to multiple contexts, the MSFC will route between the contexts, which might not be your intention.
This would mean that the SVIs for the VLANs that have been assigned to the context need to have their SVIs on the MSFC and in this case the MSFC would route between the contexts, if the SVIs for these vlans were on the FWSM then this would have not been possible.
i want understand this concept in relation to other vlan that are assigned to FWSM or MSFC and not just inside and outside vlan
Can you please clarify this point to me.
Once again thanks for answer
Correct Answer
Kureli Sankar Tue, 06/08/2010 - 08:05
  • Cisco Employee,
Sheikh,
-KS
