ASA 5520 - what's using my memory?
Jun 8th, 2010
I have 2 ASA 5520's in active standby mode, they are on IOS 8.2(2) and have 512mb of memory.
For some reason the memory usage went from 70% to 85% at 4pm yesterday.  When I look back at the the changes at that time all I did was add a subnet to a rule.  I took the subnet back out of the rule today and the memory has remained the same.
Any ideas on when I can do please let me know.
Kureli Sankar Tue, 06/08/2010 - 06:43
  • Cisco Employee,
It is an involved process to find out exactly what process is consuming the memory.
I'd suggest opening a TAC case so we can collect "sh mem detail" a few times in 3 hours or so and then sh mem binsize <> for the size that has consumed the most memory and then decode output value and match it to a process.
Do you have threat detection enabled? This is known to consume memory.  Issue "sh run threat". To disable it copy and paste the lines with a "no" in front of it.
Then watch the mem and see if it goes down.
-KS
Andy White Tue, 06/08/2010 - 07:09
The threat detection is already off.
I would like to try what you suggested but got a little lost, I have attached my 'sh mem detail', how do I do the binsize then match against a process?
Many thanks!
