UDLD message timer vs. time out interval
Jun 8th, 2010
i understand the meaning of the message timer, but what ist the use of the time out interval? On the cisco webpage i found: "When UDLD neighbors are established,           the configured message interval is sent and the timeout interval for  that peer           is calculated to be (3 * message_interval)."
But on my switch the output shows 2 kind of timers:
Interface Gi1/1
Port enable administrative configuration setting: Enabled / in aggressive mode
Port enable operational state: Enabled / in aggressive mode
Current bidirectional state: Bidirectional
Current operational state: Advertisement - Single neighbor detected
Message interval: 15
Time out interval: 5
    Entry 1
    Expiration time: 42
    Cache Device index: 1
    Current neighbor state: Bidirectional
So, what is the difference between Message Interval and Time out interval, can somebody explain?
Tia,
Stephan
Giuseppe Larosa Tue, 06/08/2010 - 09:21
  • Hall of Fame,
    Founding Member
Hello Stephan,
as in other show like sh cdp neighbors the Expiration time tells you for how much time the neighbor will be considered valid
if we do multiple times the following:
sh udld te1/1 | inc Expiration time:
    Expiration time: 15
switch#sh udld te1/1 | inc Expiration time:
    Expiration time: 21
in my case I see
sh udld te1/1
Interface Te1/1
Port enable administrative configuration setting: Follows device default
    Entry 1
    Expiration time: 14
    Device ID: 0169C561C0
    Port ID: Te4/8
    Neighbor echo 1 device: FOX1027012K
    Neighbor echo 1 port: Te1/1
expiration time is varies between 15 and 21 seconds after receiving a message it looks like it can be message interval 15 + timeout interval is the effective expire timeout
Hope to help
Giuseppe
ssieger Wed, 06/09/2010 - 00:28
Hi Giuseppe,
so if i plan to use udld in a rstp environment, in a case of an unidirctional link i have to consider a maxage of 4-6 secplus listening and learning state 15 sec each (because there is no rstp communication and the system will fall back to 802.1D). That result in a total time from blocking to forwarding of approximately 34-36 sec. right?
UDLD have to recognize the link failure before a time of max. 36 sec, so if i use aggressive mode the following happens:
the timout of 5 sec expires
than 3 times of the transmit intervall expires
after that 8 additional packets are send in aggressive mode, one packet every second
So, 5 + 45 (3*15) + 8 = 58 sec , so i have to modify the transmit interval to 7 sec:
Than 5 + 21 (3*7) + 8 = 34 sec, and that is a value below the 36 sec for rstp.
Do you agree with that proposal?
Greetings,
Stephan
