SA 520w wireless issues in NG mode
Jun 8th, 2010
Has anyone else experienced wireless issue while having the device in NG mode? I have the latest firmware installed x.x.42 and have a mix of g and n clients and different OSs from Ubuntu to Win7 and XP. The N clients don't have the issue the G clients do, and that is connection drops. The signal strength is good but they still have issues connecting. Any suggestions?
charlesw Mon, 06/28/2010 - 16:31
  • Cisco Employee,
Hi:
Thank you for your post.  We would like to get more information regarding to your issue to serve you better.
For you G clients, which OS is it using?  Is it on all G clients, or particular machines have this issue?
If possible, can you private message me your configuration, so we can try to reproduce it using your spec.
One workaround to try is save your configuration and power cycle the box.
At the meantime, we will try to see if we can reproduce the issue.
Thank you.
Best Regards,
Charles
Related Content
