QoS class issue
Answered Question
Jun 8th, 2010
I have a QoS issue. Please help me figure out.
ip access-list extended SILVER-TRAFFIC
permit tcp any  10.0.0.0 0.255.255.255 eq 80
ip access-list extended BRONZE-TRAFFIC
permit tcp any  10.3.115.0 0.0.0.255 eq 80
permit tcp any  10.60.52.0 0.0.0.255 eq 80
class-map match-any SILVER-CLASS
  match access-group name SILVER-TRAFFIC
class-map match-any BRONZE-CLASS
  match access-group name BRONZE-TRAFFIC
policy-map QOS
  class SILVER-CLASS
   set dscp cs3
  class BRONZE-CLASS
   set dscp cs2
  class class-default
   set dscp default
There are 2 QoS class in this configuration. The ACL (permit tcp any  10.0.0.0 0.255.255.255 eq 80) of the silver class includes the ACL of the Bronze class. Does that means those bronze class traffic are marked as silver class, instead of Bronze class?
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello Angyu,
your understanding is correct: the order of call of the class-maps counts like in an ACL
you should rewrite the policy-map invoking the bronze-traffic first or you will be in trouble
It could be a safe measure to rewrite the ACL for silver traffic denying the other traffic
Hope to help
Giuseppe
Correct Answer by Jon Marshall about 6 years 9 months ago
It means that all traffic with the first octet of 10 in the IP address will be matched to the silver class. Nothing with a 10.x.x.x address will ever get past the silver class so all 10.x.x.x traffic will be marked with dscp cs3.
The policy-map is checked sequentially so and if a match is found processing stops so if you want bronze traffic to be marked as bronze -
policy-map QOS
class BRONZE-CLASS
set dscp cs2
class SILVER-CLASS
set dscp cs3
class class-default
set dscp default
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 06/08/2010 - 10:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
policy-map QOS
class BRONZE-CLASS
set dscp cs2
class SILVER-CLASS
set dscp cs3
class class-default
set dscp default
Jon
Correct Answer
Giuseppe Larosa Tue, 06/08/2010 - 10:33
  • Hall of Fame,
    Founding Member
Hello Angyu,
Hope to help
Giuseppe
