Jun 8th, 2010
               |-----| Cisco 1811 |=======| Internet |=======|   SA  540    |-----|
               |   AL+-----------+AW           \--v-v-v-v-/            BW+-----------+BL   |
hello guys i am fresh in this field. I tried to establish VPN between the 1811 and sa540. The VPN Tunnel is UP but from the Cisco 1811 i cannot ping to SA540 "BW" and "BL" i have defined default route and static route on both devices but from SA540 i can ping to "AL" help on this want to make communication between with
please provide step by step guide to configure the SA540.
Thank You.
Federico Coto F... Tue, 06/08/2010 - 15:55
Does the tunnel show established on the SA540?
Do you see both phase 1 and phase 2 established on the router?  ''sh cry isa sa'' and ''sh cry ips sa''
A good test (if the tunnel is established) is the following:
PING from the router's internal LAN to the internal LAN of the SA540 and check the ''sh cry ips sa'' for packets encrypted/decrypted. This will give us an idea where to look.
Are you doing NAT also?
Related Content
