Agnet ready/busy
Majdi Harb
Level 3
Level 3
hi
just wanted to check with you guys your thoughts on this:
i need to configure my UCCX script so that if an agent is not ready (agent is not logged in or not available) to route calls to option x. now, if the agent is available (logged in) but busy on another call (reserved) to route calls to option y...
a way to check the status of the agent and route based on that.
thanks
Anthony Holloway
If you are asking for a single Agent:
agent_state = Get Reporting Stats (Resource, State)
if (agent_state == 'Not Ready' || agent_state == 'Logged Out') {
     // Do something
} else {
     // Do something else
For many agents who service a queue:
logged_in_agents = Get Reporting Stats(CSQ, logged in resources)
not_ready_agents = Get Reporting Stats(CSQ, not ready resources)
potential_agents = logged_in_agents - not_ready_agents
if (potential_agents <= 0) {
     // Do something
} else {
Anthony Holloway
     // Do something
} else {
     // Do something
} else {
thanks Anthony for ur response ...
i added the variable  logged_in_agents, not_ready_agents and potenial_agents as integers, so what should be the value (can i leave it 0 as default)?
for potenial_agents i couldn't insert logged_in_agents - not_ready_agents in the value field ...it keeps saying invalid identifier
could u just plz shed some light on that
many thanks
ok i could resolve it .. i used a boolean variable called agent
so If the number logged in is less than or equal to 0 (<=) then set the boolean variable "agent" to false, otherwise set it to true.
so only one get reporting stats step then if step based on "agent" value whether true or fale
thanks
