IP phone & data in one switch
Jun 8th, 2010
Dear All,
I am designing a switch to deliver  the service for data and ip phone.
For example the odd number port of a switch  will be assigned for data
and the even number will be for IP Phone. Indeed, the each will have own vlan.
I come this solution due to cost wise, instead of having one  switch for data
and another sw for voice service.
I don't know whether Is it common practice?
Thanks&Regards,
sams
Overall Rating: 3 (1 ratings)
Leo Laohoo Tue, 06/08/2010 - 15:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Nope because this is an EXPENSIVE practice.
Modern VoIP phone have two data ports.  First data port goes from the phone to the LAN switch.  The second data port goes from the VoIP to the PC.
On your Cisco switch, you just configure  "switchport access vlan " and "switchport voice vlan ".
Hope this helps and don't forget to rate useful posts.
sam_manay Tue, 06/08/2010 - 22:00
Meaning, we just need 1 port only to serve data and IP phone?
In my case, can I use a dedicated port for data only (port 0/1) and  second port for voice (0/2)?
Once I am doing this:
This will use 2 ports, right?
Thanks for the reply.
sam
Leo Laohoo Tue, 06/08/2010 - 23:10
  • Hall of Fame,
    2017 LAN, Wireless
If you deliberately want to use one port for each, sure.  Just apply the configuration I've posted earlier to both ports.
