Client SSL VPN Issues
Jun 8th, 2010
I currently have clientless SSL access to my network with which I'm also using Cisco secure desktop. When I connect everything runs ok ie CSD installs and I login into the web portal which gives me access to configured HTTP and CIFS bookmarks. When I access files via CIFS can I configure the ASA to allow me to edit them? At the moment I can open the file, edit and save it, but when I open the file again the changes have not been saved.
Also, if I log out of the portal (still in CSD) and select the button to login in again I get a message saying that a connection already exists. To get around this I need to exit CSD (so it un-installs) and re-start the process from scratch.
Can anyone point me in the right direction with these issues?
Kind Regards
Terry
Federico Coto F... Tue, 06/08/2010 - 15:52
Terry,
If you connect your clientless SSL VPN to the ASA without using CSD, everything works fine?
Federico.
terry.tolan Wed, 06/09/2010 - 12:58
Hi Federico, thanks for your reply.
If I disable CSD, I can log back in without a problems, but still can edit any files using CIFS.
Cheers
Terry
