RIB to FIB when pinging
DialerString_2
Level 3
Level 3
Why is it that when pinging from the f0/0 (10.1.55.1) to a host (10.1.55.38) the ICMP reply are using RIB?  I have CEF enabled and I can understand why the icmp packet destined for .38 would use the FIB table. - Why would the responses use the RIB?
Jun  8 16:03:18.995: IP: tableid=0, s=10.1.55.1 (local), d=10.1.55.38 (FastEthernet0/0), routed via FIB
Jun  8 16:03:18.995: IP: s=10.1.55.1 (local), d=10.1.55.38 (FastEthernet0/0), len 100, sending
Jun  8 16:03:18.995:     ICMP type=8, code=0
Jun  8 16:03:18.999: IP: tableid=0, s=10.1.55.38 (FastEthernet0/0), d=10.1.55.1 (FastEthernet0/0), routed via RIB
Jun  8 16:03:18.999: IP: s=10.1.55.38 (FastEthernet0/0), d=10.1.55.1 (FastEthernet0/0), len 100, rcvd 3
Jun  8 16:03:18.999:     ICMP type=0, code=0
Jun  8 16:03:18.999: ICMP: echo reply rcvd, src 10.1.55.38, dst 10.1.55.1
Jun  8 16:03:18.999: IP: tableid=0, s=10.1.55.1 (local), d=10.1.55.38 (FastEthernet0/0), routed via FIB
Jun  8 16:03:18.999: IP: s=10.1.55.1 (local), d=10.1.55.38 (FastEthernet0/0), len 100, sending
Jun  8 16:03:18.999:     ICMP type=8, code=0
rtr-culpeper#sh ip interface
FastEthernet0/0 is up, line protocol is up
  Internet address is 10.1.55.1/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Secondary address 10.200.20.73/30
  Multicast reserved groups joined: 224.0.0.10
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is enabled
  IP CEF switching is enabled
  IP CEF Flow Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, Flow cache, CEF, Full Flow
  Router Discovery is disabled
  IP output packet accounting is enabled
  IP access violation accounting is disabled, system threshold is 512
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
FYI -  I can ping this device from it's LAN, but not from another network ie 10.1.38.0. -  I can ping everything else on the 10.1.55.0 network but not that one device. It's jet direct.
thanks guy and gals.
The destination is not local.
8 Replies 8
dominic.caron
Level 5
Level 5
It's not using the FIB because it doesnt have to forward the packet to another host. The router is the destination. The FIB is a Mtrie leaf data structure. Each leaf points to an entry in the adjacency table.
dominic.caron
Level 5
Level 5
And...Look's like a bad default gateway on the host...try enabling proxy arp just to test it.
Thanks Dominic and the gateway was the first thing I checked and it's set correctly!!!!
Why does it say 'FIB' here?
Got it and thanks, D.
Is the netmask of the client correct?
I would realy try proxy-arp if I was you, over the years, I've stumble over a few host with bad network implementation.
I'm going to try proxy-arp now. The all ip information is correct. 10.1.55.38/24 gw is .1... It was working early today and then the location had a power failure.
