ATM/AIM Support in 2901
Answered Question
Jun 8th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} I have some ATM/IMA circuits.  Id like  to verify that the 2901 can support ATM and was wondering if there is the same aim slot that I can put my existing aim cards in.  I suppose not.  What's my best option?
Correct Answer by paolo bevilacqua about 6 years 10 months ago
ISR G2 does not support ATM IMA. You must use ISR G1 for that, or migrate the circuits to current technology.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 06/08/2010 - 13:52
  • Hall of Fame,
    Founding Member
