Has anyone Created statoc route on the FTD sensor via the CLI?Mine looks like it goes throught bu when i FDM into it, i do not see them. Any Advice will be appreciated.Thanks.
The content you are looking for has been archived. View related content below.
Hi Guys, Tried to perform the reimage of the Cisco 5525-x firepower module to 6.0.0 but failed. I've setup the ftp server(filezilla) and uploaded the boot image to disk0 parttion without any issue, however, perform system image ftp://username:passwo...
Dear TeamI have downloaded the vfmc for esxi 7.4.X and 7.3X but i cannot deploy in VMware after deployment its retturn "operating system not found"any ideaRegards
Hello, Does anyone know why the FMC/FTD would create an sf-storage folder on a Linux Server? When I configured the remote storage I tried to point it so that the backups are stored into a certain directory, however it created a separate folder within...
Hey allI have a Firepower 1010, I need to disable the SIP ALG on it, I have access to the Web Client and Telenet access to make changes, can someone give me an easy way to make these changes, I don't have the ASA Software that could access with.
Hello, I deployed a new FTD 2110 on our company network and I'm seeing two different mac addresses on the switch port that the MGMT interface is connected to. I know that the one mac address is associated with the actual MGMT interface, but can anyon...
Hello everybody,our customer has FMCv rel. 7.2.5.1 and two Firepower 1120 in a HA running rel. 7.2.5.I have installed the FTD patch to rel. 7.2.5.1 successfully but the release that the FMCindicates is still 7.2.5 (see attached screen dump).Do you ha...
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
I am configuring ASA5516 from scratch and trying to find out the current recommended versions.Could you please advise?Curretly:ASA Software Version: 9.8(2)Firepower Extensible Operating System Version: 2.2(2.52)Device Manager Version: 7.9(2)152
Hello!I´m using FMC 7.2.5.1 in Edge browser on a 1920x1080 screen with 75% zoom in the browser.When I open "Objects", the table of Network objects is shown.When I want to start flipping through the pages to find something (because "Why can´t I just s...
Has anyone tried to setup the Azure monitoring agent to on-premises Cisco devices so that they can be monitored on Azure? Please kindly let me know the procedure/necessary configuration if anyone has done this successfully.
Hello everyone,I have a CISCO ASA 5555-X configured in multi-context mode and I want to monitor it via SNMP.However, I can't find the MIB files for this device.How can I get them?I don't have access to ftp://ftp.cisco.com/pub/mibs/supportlists/asa/as...
Hello everybody,the customer has the FMC rel. 7.2.5.1 and the Health Monitor shows the error messageSmart License MonitorSmart Agent is not registered with Smart Licensing CloudSmart License usage is out of compliancethis time for itself (see attache...
Hi there,Is Cisco Firepower have a Database for malware signature?When i check TECSEC-2599.pdf p77, the information is: FTD will first calculation the sha, and than send to FMC and FMC will check the Reputation from AMP Cloud.But i got another inform...
Hi All, I configured anyconnect vpn in ASA and its working ok. I enabled ASDM access in inside interface (10.10.50.254). After connecting to VPN, i tried to ping and connect to ASDM on 10.10.50.254 but its not working and i get "routing failed to loc...
Subject | Author | Posted |
04-17-2024 12:36 PM | ||
04-17-2024 07:38 AM | ||
04-17-2024 02:11 AM | ||
04-16-2024 11:24 PM | ||
04-15-2024 12:25 PM |
User | Count |
9 | |
7 | |
5 | |
4 | |
3 |
