bandwidth problem
Jun 9th, 2010
we have a router having two leased lines configure on that but i need to use the full bandwidth of the both link at a time, how i can do it
router config is as follows:
Current configuration : 2101 bytes
version 12.4
service password-encryption
hostname GISIL_INDE
boot-start-marker
boot-end-marker
enable secret 5 $1$IZyS$sOnoR5.pT.Cuzs61ecDzZ1
aaa new-model
aaa session-id common
--More-- ip cef
username cisco password 7 1511021F0725
archive
log config
hidekeys
interface FastEthernet0/0
ip address 203.110.81.202 255.255.255.248
--More--
*Apr 26 12:59:34.783: %MV64340_ETHERNET-5-LATECOLLISION: FastEthernet0/0, late collision error ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 203.122.32.46 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1/0
ip address 125.63.71.161 255.255.255.224
ip nat inside
--More--
*Apr 26 12:59:35.751: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not full duplex), with INDEPAY FastEthernet0 (full duplex). duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 203.122.32.45
ip route 64.0.0.0 192.0.0.0 203.110.81.201
ip route 192.168.20.0 255.255.254.0 125.63.71.162
ip route 203.110.0.0 255.255.0.0 203.110.81.201
no ip http server
no ip http secure-server
ip nat inside source route-map Internet-to-DelDSL interface FastEthernet0/0 overload
--More-- ip nat inside source route-map Internet-to-Spectra interface FastEthernet0/1 overload
ip nat inside source static 192.168.20.29 125.63.71.163
ip access-list extended Internet-to-DELDSL
permit ip 192.168.20.0 0.0.1.255 203.110.0.0 0.0.255.255
permit ip 192.168.20.0 0.0.1.255 64.0.0.0 63.255.255.255
ip access-list extended Internet-to-Spectra
permit ip any any
access-list 101 permit ip 192.168.20.0 0.0.1.255 any
route-map Internet-to-DelDSL permit 10
match ip address Internet-to-DELDSL
route-map Internet-to-Spectra permit 10
match ip address Internet-to-Spectra
control-plane
--More-- !
line con 0
line aux 0
line vty 0 4
password 7 02050D480809
scheduler allocate 20000 1000
webvpn cef
end
GISIL_INDE#
Calin Chiorean Wed, 06/09/2010 - 01:49
You have some strange NAT config there . I only see public IP subnets on this router, but you are still using NAT. Then again you have static route for private IP subnet forwarded through public IP address. I don't know your topology, but this doesn't look good.
I understand that you have 2 connection to Internet, but no dynamic routing protocol.
The easiest way to this is to have 2 default routes point to the two ISP. This will influence outgoing traffic, but not the incoming one.
Please provide more information, and let us know which interface are the ISP connected ones and which is connected to LAN.
Calin
