Cisco Switches for microsoft NLB
Giuseppe Larosa Wed, 06/09/2010 - 05:06
Hello Alsayed,
follow this link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080a07203.shtml
if multiple switches are used you need to add static entries in the CAM table also for links between the switches not only for the ports where servers are connected.
if you use multicast mode you need to use a special MAC address that is not inside the range  used by Ipv4 multicast to avoid conflicts with IGMP snooping
Hope to help
Giuseppe
jungjacques Mon, 03/11/2013 - 09:10
Hi, i've read the link of this post but i'm trying to do this on 2 4500's and i can't parameter a static MAC on 2 differents interfaces. I'm stuck with only 1. How can i do ?
IOS : 12.2(37)SG
