9971 Adding to Call Manager
Jun 9th, 2010
I have CUCM 7.1.3. I need to add the new phone model which 9971 with camera after downloading the firmware and uploaded to TFTP of  CUCM i reset the tftp, after resetting i can't find the phone model in the phones menu.
any one can help.
1 vote
rob.huffman Wed, 06/09/2010 - 05:23
Hi Ali,
You will need 7.1(3a)su1 as a minimum release version
Cisco Unified IP Phone 8900 and 9900 Series
Before using the Cisco Unified IP Phone with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Note You can install Cisco Unified Communications Manager 7.1(3) or 7.1(3a). After you install one of these releases, you must install Cisco Unified Communications Manager *** 7.1(3a)su1. ***
ali nasser Tue, 06/15/2010 - 00:40
HI, rob
i upgrade my cisco call manager from 7.1.(3) to 7.1.(3a)su1 i can find the phone set in the menu and the phone is working, but i have other issue i can't make a video call between the phones and i have a delay to call the other phone set.
pls advice.
ali nasser Tue, 06/15/2010 - 01:58
thanks for your raply, i try the two firmware (9.0.3) and (9.0.2) and its give an error msg that the video capablility is disabled by administrator.
and under the phone enterprice parameter i can't fine the vedio capability to enable it.
what is the device pack.
Aaron Harrison Tue, 06/15/2010 - 02:08
Is there a video option under the 'Product Specific section of the phone configuration page in CCMADmin? Near the bottom of the page, where you have other options like CDP enable, LLDP and so on?
ali nasser Tue, 06/15/2010 - 05:53
HI Aaron,
I download the DEVICE PACK and installed to CUCM and everything work fine.
Just for the people who wants to know the steps.
1 - Install CUCM 7.1.(3a)SU1
2 - Install Devies Pack for CUCM to enable the video capability
3 - Enable the Cisco Camera in the set configuration
Aaron, i have a delay when i call 9971 from 9971 or any type there is a delay to call, what you advice.
Aaron Harrison Tue, 06/15/2010 - 06:09
You mean you have delays whenever you dial between extensions internally? And this happens to all phones?
How long is the delay? It's common to get delays if you have an overlap in the dial plan.
e.g. you have~:
ext 1234
ext 1235
ext (or route pattern, or trans pattern or anything) 12xxxx
CCM will wait to see if you dial more digits... Take a look at the Route Plan Report (Call Routing menu in CCM0 to see if there is anything like that happening.
Please take the time to rate posts you have found useful...
Novriadi . Fri, 06/22/2012 - 20:51
Hi Aaron
I also experiencing delay when call using 9971 - SIP Phone.
When call using 7945 - SCCP Phone using this way :
1. pick up the phone -> dial extension (eg. 3333) -> wait 10s -> calling.  [this 10s delay I think is a wait time for last digit]
2. dial extension (eg.3333) -> press call -> calling without waiting 10s
When call using 9971 - SIP Phone using this way :
2. dial extension (eg.3333) -> press call -> wait 10s -> calling [this 10s delay I think is a wait time for last digit, but shouldn't occur because in our SCCP phone is normal]
in the trans pattern we have 3xxx and also have 3333 DN registered to CM.
Do you have any advice to solve this issue ?
