Sean Merrow Wed, 06/09/2010 - 05:31
  • Silver, 250 points or more
Hello Yoesa,
Since the CSM End-of-Life has been announced, there will be no new features to speak of added to the product.  IPv6 will be supported in our next-generation load balancer, the Application Control Engine (ACE) in a future release.
HTH,
Sean
yshindunata Tue, 06/15/2010 - 23:11
Hi Sean,
Does the ACE module currently support IPv6? If not, do you have the roadmap when it will support it? And how to enable it, is it just IOS Software or  does it need another hardware?
Thank you for your help.
Yoesa
Sean Merrow Wed, 06/16/2010 - 06:08
Hello Yoesa,
The ACE module does not currently support IPv6, however, it is on the roadmap.  I would recommend reaching out to your Cisco representative for details on hardware and software requirements needed for a future deployment of IPv6 on the ACE modul, as well as estimates with regard to its availability.
Thank you,
Sean
