snmp query on a dhcp server (low routers or L3 switches)
Jun 9th, 2010
is possible to monitor dhcp binding or free addresses using snmp? I found the following MIB: CISCO-IETF-DHCP-SERVER-MIB, but this MIB is supported only on the Cisco 7300, 7200 series.:-( When I tried snmpwalk on the Catalyst3560, but the CISCO-IETF-DHCP-SERVER-MIBoids is not supported:-( So the question is following: Is possible to monitor DHCP leases using SNMP on the low end Cisco platforms (800,1700, 1800, 26xx, 28xx..., Cat3560, Cat3560E, Cat3750, ...)? Thank you. Roman
ROMAN TOMASEK Thu, 06/17/2010 - 07:18
Thank you very much. I will test it. Is it supported on the L3 switches (3560,
3750)??. Roman
Joe Clarke Thu, 06/17/2010 - 08:04
Provided those switches are running 12.2(40)SE or higher, then yes.
