06-09-2010 03:06 AM
I have been looking in vain for a tool which will allow us to feed a "show ver"/"show inv" into a tool and report on EoX/PSIRT status.
We already have a configuration management tool deploying a copy of RME per customer would be an issue we would end
up with >100 copies.
Or even if the PSIRT/EOL data is made availble in some standard format such as XML we could role our own tool.
Any advice comments most welcome.
Thanks and regards
Kevin
06-09-2010 10:16 PM
You can download the raw data files (in XML format) from http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=4.1.1&mdfid=282635175&sftType=CiscoWorks+Resource+Manager+Essentials+Patches&optPlat=Solaris&nodecount=2&edesignator=null&modelName=CiscoWorks+Resource+Manager+Essentials+4.3&treeMdfId=26... . You would need to build your own tool as you can't import configs into RME without managing the devices.
06-14-2010 01:04 AM
Joe
Thanks for that already the files have been very useful. Just two questions if you dont mind:
1. As the file is updatted is it going to be availble to download ?
2. For the EoX of software I see entries like the below:
Which would suggest all 12.2SRA is EOx there is no details of specific versions. I have looked at this seems
to be a trend. How would you that say 12.2SRA18 is EoX yet 12.2SRA22 is not ?
Thanks and regards
Kevin
06-14-2010 06:48 AM
1. Yes, the file be updated in place. You will need to download new copies of it.
2. In this case, all 12.2(33)SRA code is EoL. You need to move to 12.2(33)SRC for support. If there are specific versions which are EoL, and others which are not, the data will reflect specific versions (down to the point release).
