telnet on udp ports
Answered Question
Jun 9th, 2010
Hi ,
To test if any port is active or opened by firewall or not, we can use telnet if port is tcp.
How to check if the port to be verified is udp one.will telnet work?
Thanks!
Correct Answer by michael.hutt about 7 years 1 month ago
No, Telnet only makes TCP connections.
You can try using a port scanner or something to scan for open connections.
Overall Rating: 5 (1 ratings)
Correct Answer
michael.hutt Wed, 06/09/2010 - 03:35
