NAC login page is not displayed to users
Jun 9th, 2010
I am configuring a NAC appliance for Out-of-Band Virtual Gateway model.
After the initial configuration of my NAC, am running a test by managing a port. When i connect my system to the managed port, it doesn't change the VLAN to the authentication VLAN neither do i get the login page of the NAC or access any resource on the network.
I would appreciate some help with  specific configurations to achieve this.
Thanks.
Chioma
Overall Rating: 5 (1 ratings)
Faisal Sehbai Wed, 06/09/2010 - 20:30
  • Gold, 750 points or more
Check your SNMP settings on the switch and the CAM. Are you sure that the CAM is receiving the traps?
Faisal
