Location Tracking of Nortel Phones with MSE / Aeroscout
Answered Question
Jun 9th, 2010
Hi there
actually we can track laptops and other CCX devices with our MSE and Aeroscout equipment. The problem is that we can't track Nortel IP phones. Has someone ever did this configuration and what is important to take a look at. I don't know anything about Nortel, so this would be helpful.
Thanks a lot in advance
Dominic
Correct Answer by Elliott Shawd about 6 years 10 months ago
If your AeroScout Engine is setup to track tags using CCX, I don't think you can set it up to to track fully associated clients. I would check with AeroScout though. Do you have access to Cisco WCS? You should be able to "see" the phones in there, but not necessary track them.
Overall Rating: 5 (2 ratings)
Dominic Stalder Wed, 06/16/2010 - 23:38
Hi Elliot
thanks for the answer, I know that they don't support CCX, but is this really the only way to track a device with the Cisco MSE, aren't threre other protocols like WDS or IBSS (Aeroscout)?
Dominic
Correct Answer
Elliott Shawd Fri, 06/18/2010 - 19:15
Dominic Stalder Sat, 06/19/2010 - 07:35
I think the AeroScout engine in the MSE only tracks CCX devices, so you are right that it will not work with CCX. I already asked AeroScout and they told me that it is not a problem of AeroScout, its a problem with Cisco (MSE and WCS)...
It's true, the phones are on the WCS, but can't get tracked in the maps. Maybe I try to contact Nortel and ask there.
Dominic
Elliott Shawd Sat, 06/19/2010 - 10:04
No, you cannot get "real time" tracking out of WCS, but you can track your Nortel phones just like any other client in WCS. You can get association reports and, with the MSE, location and triangulation on a map, which should update from your controllers pretty frequently, and track stuff that way.
Leo Laohoo Sat, 06/19/2010 - 17:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How about putting AeroScout tags on the Nortel phones?
Dominic Stalder Sun, 06/20/2010 - 05:02
Both are not practicable, because it is the emergency hospitalisation and they need realtime tracking. Putting a tag on the phone makes the phone even more "bigger".
Dominic Stalder Sat, 02/19/2011 - 07:25
Hi there
just as an information, it was a licensing problem, the MSE / WCS run out of license and so the Nortel phones (and many other clients) were not tracked.
Now it works great.
Dominic
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
