Public Distribution Lists Unity 7.0
nixon1234
We have a need to send a broadcast voice message to a DL for only a handfull of users. I looked into broadcast messaging but you can not edit users as far as I can tell. I set up a test Public DL and added a few users into it but I seem to be missing a step or I am not really sure how it is supposed to work. I checked for documentation and find it on how to set up the DL but not much else.
Any help would be great!
Thanks!
Rob Huffman
HIWilliam,
DOH!! It would help if I could read
Try it first with you as the Owner;
System Administration Guide for Cisco Unity Release 5.x (With Microsoft Exchange)
Managing Distribution Lists
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusag240e.html#wp1047746
https://supportforums.cisco.com/docs/DOC-3310
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Rob Huffman
Hi William,
No worries, the first couple I've set up on Unity Connection lost me
as well
One thing we have done is to assign a "phantom" DN to System DL's
to make it easier to send to them. Sending by name is a tad tedious
to say the least. Use any unused number for this. here is an example;
So you have a new test_dl
assign 1333 for extension on Edit Distribution ListPage
set up/assign members
exit
Access your mailbox
enter PIN
Press x to send (depends on conversation you are using)
record new "Broadcast" message
press#
send to 1333 press# to send
MWI lamps will light on test_dl member phones
and new "Broadcast" message will be received.
Cheers!
Rob
This is standard unity not unity connection..does this make a difference?
Do I set the owner as myself to test?
Rob Huffman
HIWilliam,
Cheers!
Rob
just what I was looking for !
thanks!
