Ports Issue - Strange behavior
Answered Question
Jun 9th, 2010
Hello
on 4500 catalyst switch I get error on two ports.
show int gigabitEthernet 4/22
GigabitEthernet4/22 is down, line protocol is down (notconnect)
show int gigabitEthernet 4/13
GigabitEthernet4/13 is up, line protocol is up (faulty)
rest all ports are working.
I changed and tested all speed and duplex options. ( tested Speed 10, 100, auto as well )
I changed the cable ( checked with Cat 5 and Cat 6 cables )
I changed laptops to check the ports 4/22 and 4.13
Changed the ports settings to default
shut / no shut
Any Help !!!
Saquib
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Saquib,
as TJ has noted the linecard is flagged faulty meaning that is not considered fully operational
attempt to extract and to insert it again in a maintanance window
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
tj.mitchell Wed, 06/09/2010 - 10:18
  • Bronze, 100 points or more
Has this issue about 3 weeks ago. Pull and reset the blade in the chassis, then call TAC to get a new blade as it will go faulty again, but who knows when.
TJM
Giuseppe Larosa Wed, 06/09/2010 - 13:54
  • Hall of Fame,
    Founding Member
Hello Saquib,
post sh module and sh ver | inc image
I would consider to do what TJ has suggested to reseat the linecard.
Also checking the linecard test results at power on can be a wise step
Hope to help
Giuseppe
saquib.tandel Thu, 06/10/2010 - 07:55
here is the details
System image file is "bootflash:cat4000-i9k2s-mz.121-19.EW1.bin"
show module
Chassis Type : WS-C4506
Power consumed by backplane : 10 Watts
Mod Ports Card Type                              Model
1     2  1000BaseX (GBIC) Supervisor(active)    WS-X4515
2    24  10/100/1000BaseTX (RJ45)               WS-X4424-GB-RJ45
M MAC addresses                    Hw  Fw           Sw               Status
1 1 3.1 12.1(20r)EW1 12.1(19)EW1, EAR Ok
2 001                              Faulty
tj.mitchell Thu, 06/10/2010 - 08:08
That is exactly what my show module looked like with the faulty flag set.
TJM
Correct Answer
Giuseppe Larosa Thu, 06/10/2010 - 08:10
  • Hall of Fame,
    Founding Member
Hello Saquib,
Hope to help
Giuseppe
