modem inout - for AUX ?
Jun 9th, 2010
Hi All
We are standardizing on AUX port configurations for thousands of end routers.. The understanding that Im in is - incoming calls to modems on AUX port would work only if we have the "modem inout" command on the line aux.. Is that right ? My questions:
1) would the aux port on a router work without the modem inout command ? Do new versions of code have this enabled default ? (this is because i heard from my counterparts that they were able to dial without this command) ...
2) If the above is true, what are the other ways that we can identify - "show line" shows, but through CLI commands is it possible ? because we are running compliance throgh NCM now, and NCM just checks command sets / CLI , and not show outputs...
Thanks in advance
Overall Rating: 3 (1 ratings)
francisco_1 Wed, 06/09/2010 - 08:24
  • Gold, 750 points or more
My understanding is the modem inout command  allows inbound & outbound calls on the modem
Francisco
sblavanya Wed, 06/09/2010 - 08:42
Ya Francisco.. So would you say AUX port will not work without that command ? we are mainly focussing on inbound dialing, and not outbound..
