DBWorker / DBLookup in ICM 7.5 for a SQL server with instance
Endorsed Question
Jun 9th, 2010
can anybody give me the correct syntax for DBWorker Login and for DB Lookup for a SQL server with an instance.
I know the syntax for DBWorker Login without SQL instance (\\SQLServername\DBName=(username,password)) and the DBLookup syntax (\\SQLServername\DBName.TableName) but it doesn't work if I have an instance on my SQL server. I tried the following syntaxes:
DBWorker Login
\\SQLServername\Instance\DBName=(username,password)
\\SQLServername/Instance\DBName=(username,password)
\\SQLServername.Instance\DBName=(username,password)
DBLookup
\\SQLServername\Instance\DBName.TableName
\\SQLServername/Instance\DBName.TableName
\\SQLServername.Instance\DBName.TableName
but nothing was working :-(
Cheers,
Tobias
VIP Endorsed by Gergely Szabo
david.macias about 3 years 1 month ago
It has been maybe 7 years since I've used DBWorker, but from what I remember an instance is not supported. Move this over to your IVR, it will make your life a lot easier.
david
Overall Rating: 5 (2 ratings)
korolevec Wed, 05/28/2014 - 02:09
I have the same ploblem. Anybody know the correct answer?
david.macias Wed, 05/28/2014 - 06:36
  • Blue, 1500 points or more
david
Gergely Szabo Thu, 05/29/2014 - 01:20
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
I can only agree with David, that's why I am endorsing his answer.
Another option I would consider is the Application Gateway protocol (GED-145) for simple in'n'out interactions.
G.
