configuration clock module IPS
Jun 9th, 2010
I am setting my IPS module but I have trouble putting on the hour. I'm doing it via NTP but when I go to events I get the hour badly adds six coreg hour. I can do to this.
Scott Fringer Wed, 06/09/2010 - 09:47
  • Cisco Employee,
Have you also configured the timezone offset  and timezone on the sensor?
conf t
service host
time-zone-settings
offset
Scott
alfredoelias Thu, 06/10/2010 - 08:45
time-zone-settings
standard-time-zone-name CST
offset 0
exit
ntp-server 201.247.152.233
sh clock
21:15:22 CST Tue Jun 08 2010
This is the configuration and the problem persists
Scott Fringer Thu, 06/10/2010 - 09:06
  • Cisco Employee,
That's the problem - your offest from GMT is set to 0.  For CST the offset should be -360 with the CDT offset automatically changing to -300 (when you enable summertime in the configuration)
Scott
alfredoelias Thu, 06/10/2010 - 09:31
exit
offset -360
exit
the problem persist
Scott Fringer Thu, 06/10/2010 - 09:51
  • Cisco Employee,
Could you provide the following output:
sh clock
sh stat host
Scott
Scott Fringer Thu, 06/10/2010 - 10:43
  • Cisco Employee,
I see the 'sh stat host' output, which indicates successful NTP server synchronization.
I do not see the current output of 'sh clock'.
From the output, is this an AIP-SSM or an IDSM-2 or a different IPS module?
Scott
alfredoelias Thu, 06/10/2010 - 11:45
Hi Scott
thanks for you help this is module IPS in ASA I send the show
ROM-TLC-MIPS-01# sh clock
11:25:31 CST Thu Jun 10 2010
the time is corect but in my view IPS events shows me the 6 hours in advance
Scott Fringer Thu, 06/10/2010 - 11:48
  • Cisco Employee,
OK - so the time is correct on the sensor; that is now confirmed.
Where are you viewing the events that you are seeing the 6 hour time difference?  Are you using IEV, IME, CS-MARS, another tool?
Scott
alfredoelias Thu, 06/10/2010 - 11:51
I can see events in the IPS monitor I do not use anything else only IPS
Scott Fringer Thu, 06/10/2010 - 11:55
  • Cisco Employee,
The event viewer within IDM should present the event in both the sensor local time and sensor UTC time.
Events displayed on the CLI of the sensor via 'sh even alert' should also provide the event time in both local time and UTC time
Scott
