IPCC-Verint integration
Jun 9th, 2010
I have an CUCM 6.1.3 with IPCC express 7.0(1) build 168.
We are going to record using Verint Impact 360. The Verint
engineers are asking for some parameters that I don't know where to find it:
- The IPCC's CTI Server IP Address (side A) (I supose this is the IPCC Server IP Adress)
- The IPCC's CTI Server Port (side A)
- The ID of the PIM connected to the CallManager's ACD.
- client ID, client password
Can you help me??
Thanks!!
Edward Umansky Wed, 06/09/2010 - 10:30
That information is applicable to a UCC Enterprise or ICM system, not to a UCC Express system. Verint does provide UCCX integration, I believe it works through a database connection not a direct CTI link.
anavalverde Thu, 06/10/2010 - 02:43
Thanks Ed.
We are going to install Verint Ultra (not Witness), Does it work using a database connection too? I'm trying to find some document of the platforms integrations in the Cisco web but I haven't found anything.
david.macias Thu, 06/10/2010 - 04:38
Verint should have this documentaiton and not Cisco, have you checked with Verint?
david
lohjintiam Mon, 11/01/2010 - 22:51
Is there any additional licensing required on Cisco's end for integration with ICM CTI / HDS?
Thanks!
-JT-
