2960S uplink to 3750
Jun 9th, 2010
I just purchased a bunch of 2960S WS-C2960S-48FPD-L switches that I will use as distribution layer switches.  My top of rack switch is a 3750 switch running layer 3 with locally distributed VLAN's.
I want to connect each 2960S to the 3750 via port 48 and port 47 using etherchannel trunks BUT I was curious as to pros and cons of doing this vs using the GBIC ports 1 and 2.  Do the gig ports on the 2960S share an ethernet controller vs the GBIC ports having their own ethernet controller?
Any advise will be helpful.
Adam
dominic.caron Wed, 06/09/2010 - 13:27
  • Silver, 250 points or more
The FAQ say the 2960S is build around a single ASIC...
Related Content
