AP1200 and Least Congested Frequency
Jun 9th, 2010
Hello Everyone,
Is it every a good idea to allow the APs to be set for "Least Congested Frequency"?   Especially in a hotel type environment?  There were some APs thrown up by another company without a site survey being done.  They choose to set all the APs to this setting for whatever reason.  Our wireless team is going in behind them to straighten this out but since I am still on my learning curve I thought I would ask here.  There are 4 APs on every other floor in an 8 story hotel.  Some are within 50-100 feet of each other.
Thanks in advance!  All replies rated
Overall Rating: 4 (1 ratings)
Rob Huffman Wed, 06/09/2010 - 11:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Angel,
When you configure the AP, Cisco recommends that you disable the option to search for the least-congested channel. Cisco recommends that administrators manually set all RF channels according to the data gathered during the site survey and site survey verification steps. If you use the option to select the least-congested channel, the AP will change to a different channel every time its power is reset, thus leaving no predictability and negating the time and effort spent on the site survey.
The default channel setting for the AP radios is least congested. At startup, the AP scans for and selects the least-congested channel. For the most consistent performance after a site survey however, Cisco recommends that you assign a static channel setting for each AP.
From TAC
https://supportforums.cisco.com/docs/DOC-4700
From [email protected]
https://supportforums.cisco.com/message/1312810#1312810
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Leo Laohoo Wed, 06/09/2010 - 15:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
It's too bad you can't replace the APs with 3500i/e.
