FWSM.2.3 (Packet-Tracer)
Answered Question
Jun 9th, 2010
Hi All,
I've been trying to figure the syntax for a "packet-tracer" like command for FWSM 2.3. Does the IOS support this command?
If not, does anyone know an alternative to test ACL/NAT rules in FWSM 2.3 without actually sending a real traffic thru it?
Thanks in Advance.
Correct Answer by edadios about 6 years 11 months ago
Packet Tracer is not available to FWSM codes at the moment.
There is no simulation type commands that you can use with the FWSM code at the moment. You wqill have to test with real traffic, and check logs or do packet captures, to check for results.
Overall Rating: 5 (1 ratings)
Correct Answer
edadios Thu, 06/10/2010 - 16:17
  • Silver, 250 points or more
