FAX config on 2811??
Answered Question
Jun 9th, 2010
I have a 2811 VGW registered to CUCM 7.02, is it an H.323 gateway.  Local PSTN is coming in on a PRI circuit connected to the VIC-2TMFT-T1/E1.  One of the inbound numbers on that PRI is a fax number (5551236789) that I need to port out of the FXS card (voice-port 0/2/0) to the fax machine.  Also need to allow for outbound fax sending.
Would someone mind posting sample config that will help me understand and accomplish this?  I find plenty of examples, but don't completely understand what is pertinent for creating both inbound/outbound config.
dial-peer voice 21 pots
description Fax
destination-pattern 5551236789
port 0/0/0:23
forward-digits 0
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
fax rate voice
voice-port 0/2/0
translation-profile incoming Fax
description Fax
Jason
Correct Answer by Jonathan Schulenberg about 6 years 7 months ago
First, your incoming dial peer should cover all incoming calls on the PRI and include the direct-inward-dial command. This will cover you for the inbound call leg. The outbound dial peer could look something like this:
description Fax
destination-pattern 5551236789 <-- This assumes that the provider is sending you 10 digits on the PRI.
incoming called-number . <-- This is used to match this as an incoming dial peer for outbound faxes.
voice-port 0/2/0
codec g711ulaw  <-- used for passthrough
fax rate voice <-- used for passthrough
fax protocol t38  ls-redundancy 0 hs-redundancy 0 fallback cisco <--used for fax relay
You do not need both the passthrough or relay commands. I would recommend just using the relay command.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Wed, 06/09/2010 - 14:56
You don't need any fax commands for that.
Just configure the DP with the right numbers, and that's all.
Correct Answer
Jonathan Schulenberg Thu, 06/10/2010 - 03:59
description Fax
voice-port 0/2/0
