CME 8.0 gui displays a gray page with no icons
Jun 9th, 2010
Hey Everyone!
I have read through the other threads but can't seem to find why I am seeing only a grey GUI page without the rest of the GUI icons and buttons when I go to the http://...../ccme.html page.
I used the archive tar /xtract flash: command to extract my CME gui files to flash.
When I look in the flash I see the following listings:
60           0 Jun 09 2010 16:41:12 gui
61      829440 Jun 09 2010 16:41:16 gui/admin_user.html
62      677820 Jun 09 2010 16:41:20 gui/admin_user.js
63        1029 Jun 09 2010 16:41:22 gui/CiscoLogo.gif
64         615 Jun 09 2010 16:41:22 gui/CME_GUI_README.TXT
65         953 Jun 09 2010 16:41:22 gui/delete.gif
66       16344 Jun 09 2010 16:41:24 gui/dom.js
67         864 Jun 09 2010 16:41:24 gui/downarrow.gif
68        6146 Jun 09 2010 16:41:24 gui/ephone_admin.html
69        4558 Jun 09 2010 16:41:24 gui/logohome.gif
70        3866 Jun 09 2010 16:41:26 gui/normal_user.html
71       78428 Jun 09 2010 16:41:26 gui/normal_user.js
72        1347 Jun 09 2010 16:41:26 gui/plus.gif
73         843 Jun 09 2010 16:41:28 gui/sxiconad.gif
74         174 Jun 09 2010 16:41:28 gui/tab.gif
75        2432 Jun 09 2010 16:41:28 gui/telephony_service.html
76         870 Jun 09 2010 16:41:28 gui/uparrow.gif
77        9968 Jun 09 2010 16:41:28 gui/xml-test.html
78        3412 Jun 09 2010 16:41:30 gui/xml.template
79     1848343 Jun 09 2010 16:41:38 GUI-1.3.3.SBN
80     1892036 Jun 09 2010 16:41:48 GUIH-1.3.3.SBN
On my 2811 router I typed in the command:
ip http server
no ip http secure-server
ip http path flash:gui
I have also tried
ip http path flash:gui/
with the same problem
Any recommendations on what I am doing wrong?
All responses are greatly appriciated!
Thanks in advance!
Overall Rating: 5 (3 ratings)
paolo bevilacqua Wed, 06/09/2010 - 16:36
  • Hall of Fame,
    Founding Member
Check exact IOS used against exact GUI used.
That is indicated in the CME download page.
JessicaBroy82_2 Thu, 06/10/2010 - 09:52
I erased the flash and started over again making sure to use the exact IOS and CME version you like mentioned and everything seems to be working now.
Thanks for your help!
paolo bevilacqua Thu, 06/10/2010 - 10:38
  • Hall of Fame,
    Founding Member
You are welcome, thank you for the nice rating and good luck!
mcappelli Tue, 05/31/2011 - 05:41
I'm sorry but i dont understand.
I'm using IOS Software c2800nm-spservicesk9-mz.151-2.T3.bin and CME Version cme-151-2Tv1.zip as CME Compatibility Matrix says:
Cisco IOS Release 1:                      15.1(2)T
Cisco Unified CME Version:             8.1
Cisco Unified CME GUI Version 2:    8.1.0.0
I have the same problem of Jessica.
Am I using a wrong CME version?
Thanx
paolo bevilacqua Wed, 06/01/2011 - 01:51
  • Hall of Fame,
    Founding Member
All seems right in you case and if still troubles you can either try a CME 8.6 upgrade, or contact the TAC.
mcappelli Wed, 06/01/2011 - 03:29
nothing to do Paolo.
I downloaded CME 8.6 and used this Gui files but it doesn't work.
It still remains gray
paolo bevilacqua Wed, 06/01/2011 - 04:19
  • Hall of Fame,
    Founding Member
You also need IOS 15.1(4)M for CME 8.6
mcappelli Wed, 06/01/2011 - 06:16
Nothing to do Paolo also using IOS 15.1(4)M for CME 8.6.
It sounds really strange.
I'm not able to use the GUI...
paolo bevilacqua Wed, 06/01/2011 - 06:38
  • Hall of Fame,
    Founding Member
Post http configuration and GUI directory ?
mcappelli Fri, 06/03/2011 - 00:43
Hello Paolo,
Now it works !
I uploaded at latest IOS version and GUI and now it works perfectly.
This case is closed and thank you again.
Marco
paolo bevilacqua Fri, 06/03/2011 - 04:01
  • Hall of Fame,
    Founding Member
Thank you for the nice rating and good luck!
