VPN OK on 1812 - not on 2811 !!!
Answered Question
Jun 9th, 2010
I'm loosing my mind... I configured a remote IPSec VPN client access on 2 routers 1812. It works like  charm.
I take the same config and apply it on a 2811, it doesn't work...Error during IPsec phase 2.
I re-re-re-re-rechecked the config, it's perfectly matching the config done on the 1812. (and I use same template for 876, 1841,....)
I tried 4 different IOS 12.2.24T3 Adventerprise, 12.2.15T13 adventerprise and Advipservices, and also 12.2.25c adventerprise. Nothing changes.... still the same error...
I've apply this config on another 2811, same issue. Is there anything wrong with this model concerning IPsec VPN client config ???? Or should I use a specific IOS ?
Thanks for sharing your experience,
Olivier
Config is:
aaa new-model
aaa authentication login default local
aaa authentication login userauth local
aaa authentication ppp default local
aaa authorization exec default local
aaa authorization network groupauth local
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp client configuration group mmrouter008
key xxxxxxxxxxxxxxxx
domain xxxxxxx.com
pool POOL_VPN
acl 134
crypto isakmp profile mmrouter008
   match identity group mmrouter008
   client authentication list userauth
   isakmp authorization list groupauth
   client configuration address respond
crypto ipsec transform-set vpnuser_trans esp-3des esp-md5-hmac
crypto dynamic-map mydynamicmap 10
set transform-set vpnuser_trans
set isakmp-profile mmrouter008
reverse-route
crypto map MAPPP 100 ipsec-isakmp dynamic mydynamicmap
int fa0/0
crypto map MAPPP
ip local pool POOL_VPN 10.50.10.1 10.50.10.254
access-list 134 permit ip 192.168.71.0 0.0.0.255 10.50.10.0 0.0.0.255
Correct Answer by Federico Coto F... about 6 years 9 months ago
Oliver,
Should work as you said.
What is the error specifically that you get regarding phase 2?
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Wed, 06/09/2010 - 15:02
  • Green, 3000 points or more
Oliver,
Federico.
olivier.jessel Thu, 06/10/2010 - 00:08
Hi Frederico,
Here is the log of the VPN connection. (debug cryp isakmp)
The error I can see is:
ISAKMP:(0:1:SW:1): phase 2 SA policy not acceptable! (local 195.243.171.112 remote 195.243.171.97)
ISAKMP: set new node -1712530148 to QM_IDLE
ISAKMP:(0:1:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
I precise that 195.243.171.112 is the VPN router.
It's just strange. I use this config many times and it's the first time I have such problem.
Olivier
olivier.jessel Thu, 06/10/2010 - 00:39
wwooooo OK I found out the issue.
I have HSRP on the interface where the crypto map is applied.
The router replies with the physical IP address and not with the virtual IP address. Then IPSec phase 2 fails !
Does anyone knows how to make both working together ???
Thanks in advance
Olivier
olivier.jessel Thu, 06/10/2010 - 02:15
OK, I finally fix this HSRP+IPsec dynamic map config.
Now it works. I'm gonna test all of this when I will cofigure the second HSRP router.
Thanks again for your help ;-)
Olivier
