How Do I Configure an SPA3102 with Analog Phone, Analog Line & Voip
Jun 9th, 2010
I need to configure an SPA3102 as follows:
An analog telephone
An analog telephone line (POTS line)
A VoIP service (Voip Service through 888voipstore.com)
There are NO VoIP phones being used.
I want incoming calls from the PSTN (analog telephone line) to 'ring through' to the analog telephone.
I want outgoing calls from the analog telephone to be 'routed' to the PSTN line (the analog telephone line) when they are 'local' calls (not 1+).
I want outgoing 911 calls from the analog telephone to be 'routed' to the PSTN line (the analog telephone line).
I want outgoing calls from the analog telephone to be 'routed' to the VoIP Service, when those outgoing calls are 'long distance' (1+).
I can not figure out how to configure the SPA3102 for the above.
Help! :-)
   John
Alberto Montilla Fri, 06/11/2010 - 05:38
Dear Sir;
I suggest you read the ATA administration guide. There is a full section about dial plans for SPA3102. You need to modify the dial plan for achieving the desired behavior.
The admin guide is on the documentation section of the ATA area of this community.
Alberto
