2900 password help
Answered Question
Jun 9th, 2010
i recently bought a catalyst 2924 XL on craigs list (easy solution to what i needed), but the person i bought it from doesnt know the enable password on the console line, is there a way i could grab it or reset it??
need some help on this, Thanks.
Correct Answer by Reza Sharifi about 6 years 4 months ago
Hi Nate,
Just follow this link for password recovery procedurefor for Cisco Cat switches
Overall Rating: 5 (2 ratings)
Reza Sharifi Wed, 06/09/2010 - 19:03
You can keep the current config but I would just wipe it and start fresh since this is new switch to you
nate faulds Thu, 06/10/2010 - 05:16
i went to rename the config, it renamed, then i tried deleting the config.text left over, but the permsisions are read only, there a way i can delete the config file or format the config file/what i need to format to clear out the current config
Related Content
