Unable to browse by IP if destination NAT is used
Jun 9th, 2010
I am using an ASA between our organisation and another. This link is used for many things, including http. If I browse to the actual IP of the server I have no problem - http://20.1.1.20, however if I configure destination NAT, so the web server is presented as a differnet IP to us, it no longer works - http://10.10.10.10. I noticed that the host field in the http request remains as the actual IP I browsed to - 10.10.10.10. Is this the correct behaviour. Should the ASA NAT this? I don't have a problem if I browse by name.
PC-------(in)ASA(out)----------Web-Server
PC = 10.1.1.1
Web-Server = 20.1.1.20
static(out, in) 10.10.10.10 20.1.1.20
Thanks.
Federico Coto F... Thu, 06/10/2010 - 06:51
Hi Phil,
After doing the destination NAT:
Can you PING 10.10.10.10 from the PC?
What does a Packet-Tracer show us?
Federico.
phil-nicaud Thu, 06/10/2010 - 07:26
The issue is with the other organisation. They are dropping/ignoring packets with a HTTP Host field that they don't expect ie of the new IP I"m using. If I use the name it's fine.
I am simply asking whether it's normal to not NAT the HTTP Host field. I'm pretty sure it is, but wanted to double check.
Related Content
